nite-ize 3 emitter drop in for AA minimag.
CHEERS
-Cheap ~$6
-Retains the OEM MAG water resistance.
-Just bright enough to be useful, yet dim enough to avoid blinding you when your eyes are dilated at night.
-Uses cheap $9 host.
-Runs for a LONG time on any 2AA cell.
-Easy to install.
-Reverse polarity protection
-Runs cool, IE, no thermal issues.
-Durable, I have lost count how many times I have dropped mine. At least a dozen or so.
JEERS
-Fugly blue tint, my biggest complaint :green:
-Strange rings and imperfections to the extreme sides of its floody beam.
-Bezel needs to be tightened ALL THE WAY (tight) to securely seal water out between the lens front and bezel rim.
Neutral (may be good or bad depending on your preferences)
-floody, no hot spot.
-Only throws 12-15 feet, beyond that is nothing.
-9 Lumens
-The emitters come from the factory all "bent" and leaning all over the place, rather than pointing straight ahead. I dont know if this makes a difference, but, straightening the LEDs so they are all parallel is something I did to my module.
Overall for $6 its a good value, and it will transform an incan minimag into a very serviceable close-range light. Its great for close range use at a camp site and inside a tent. I have MUCH brighter lights, yet I continue to use this one all the time. Although I think the much smaller Fenix E01 EDC accomplishes the same thing.
IMHO a DIY a lens diffuser on shiningbeam RC-N3 Q5, might be worth your consideration.
