Thanks for the tip but in my desperation I already went there, their closes sizes are 35mm and 42mm, 35 will slip out the front while 42mm will not fit. This just happened 5 min. ago, in fact if it wasn't over
, I just went to go upstairs and I picked up the light, as I yelled in pain
nearly drooping it again! I had put the light back together again not realizing that the glass acted as a nonconductor between the body and the bezel
, thus for 5 min. my brand new batteries were shorting out causing the whole light to get to least 175 degrees "the battery's metal foil was twisting and melting off:eeksign:!" luckily there is no plastic to melt inside:thumbsup:.
