KDOG3
Its ok. For whatever reason I was expecting the most spectacular beam of light from this thing from all the hype here on CPF. ( In fairness, the hype was from other CPF members, NOT Gene.) I certainly wasn't dissappointed by the thing, but I wasn't feeling flashlight "nirvana" either. I took it into a dark room (ok, the bathroom) and did a ceiling bounce test with my E1B and they seemed exactly the same as far as output which means one of two things: The M60L isn't putting out 140-ish lumens as stated, or I have a over-achieving E1B. I'm 95% certain the latter suspicion is correct. Independent testing showed that the E1B is pumping out around 120 lumens per another CPFers' testing ( I don't remember who). Coupled with the fact that I still have the Lexan lens in the G2 since the UCL I ordered hasn't arrived yet, I'd say the output claim is pretty legit. Kudos' to Gene for that. And I must say that the build quality is excellent. This thing looks and feels like it could survive almost anything. The emmiter is PERFECTLY centered. And of course the E1B won't go 4.5 hrs like the M60L. Even with 2 batts (using ultra simple math here) the E1B would "only" run 2.6hrs on high. Still good for a little light though. But my point here is that the driver Gene is using must be kick-azz. And it still has plenty of throw for throw junkies like me. My only real complaint is beam quality. From the beamshots all over here is seemed like it would be more uniform but its similar to the optics in the E1B. Its not bad mind you. Just not what I was expecting.
Well this is just one CPFers' thoughts on the M60L. YMMV of course!
