OK, I was just reading the other post comparing the Brinkmann and the Minimag and noted that someone measured 1 ohm of resistance in the Kroll.
I thought, Wow, that's pure BS. Especially for power hungry modules like my sandwiches...
OK, Some of this on my end is lack of initiative. I've been selling them and have never looked into the reliability and quality... So, here goes.
I take a junky Kroll. It's been lying around and has been used many times. I measure the on resistance at 12+ ohms. Wow!! Now that is real junk! Can this be fixed?
I reach back into my limited memory archives and pull up Daniel Ramsey fix for the Brinkmann. Nygel...
Here's what I did. I carefully pull all the springs off and out of the plastic housing. I clean nothing... I apply some nygel on all the contact edges of the springs before re-inserting them. (NOTE: The battery contact spring is majorly rusted or tanished...)
The measured on resistance is now 0.2 ohms and stable again.
The second thing I did was the thread contact spring on the side. I rotated it so that the bottom most spring is on the inner most portion where the tab makes contact. This only makes sense and could be a cause of intermittent operation.
Lastly, The side spring. Just plain stupid, but, I can see that the spring will ride the grooves of the minimag barrel as it is screwed in. I've heard some of my Krolls jump threads part way in. This could mean that the spring has now jumped upward to align with the threads and thus never make contact. So, be aware that fiddling with the side spring and shaping it so that it is as close to the threads of the battery tube before inserting will cause less spring jumping.
Lastly. the same nygel lube works great on Brinkman switch too. It makes it work more reliable.
Hope this helps and I'd like to hear feedback if this does indeed solve some of the Kroll switch problems and intermittent usage.
I actually think that once properly lubed and set, the Kroll is a very solid and reliable switch assembly. (IMHO) /ubbthreads/images/graemlins/smile.gif
Wayne
Wayne
