Does anyone make a lens that will fit into or onto (or into) a 6P head that will focus the beam down to make it a thrower?
IPSC_GUY
SIERRA II ALPHA
You could use an aspheric lens to really tighten the beam up. It would probably require some custom work to make though.
Hmmm... there's an idea: Aspheric D26 dropin :devil:
My G2Z with DX aspherical lens and R2 dropin. It took some grinding (Dremel tool) to fit in. I also had to use the upper ~3mm portion of a P60 dropin to get the spacing just right. I just cut the upper lip of the LA off and dropped in in the bezel behind the lens.
The beamshot is from about 15 feet in my well lit bathroom at 3pm. Combined with the Surefire difuser, it's a very versitle light.
Sorry to be the last one to catch on... but KD already sells 28mm aspherical lenses HERE is that the kind of thing you had in mind? :thinking:
I guess you'd also need a crenelated bezel to provide some level of protection to the lens too? :thinking:
