Malkoff Clip on Maglite XL 100!
RedLED
Palm Springs, CA, Beverly Hills, CA, Washington, D
Just picked up a new Mag-Lite XL 100. Fun little light, and the UI is cool.
What this post is about is they are both almost 26mm, (Around 25.50mm) In diamiater. I used my calipers to measure, and if you pushed the Delrin shroud just past the tail cap, you can add a clip to the light!
I think it will work, and an going to give it a try.
The smooth area on the XL100 is the same size as the knurled area on the malkoff MD2. (Around 25.5mm)
You could also drill a hole in the shroud, and put a ring thru it for a lanyard attachment.
Placing order for clip tonight!
Best,
RL
Vesper
Puget Sound, WA
Great idea. Really looking forward to your results...
It would make a great anti-roll addition to the XL100.
