So if I bought just a Fenix E01 from DX would the quality be there? or do I need to buy from a Canadian Vendor?
If I could get a link or two it really really helps.
what about $45 I think that's his max.
Thanks,
Ollie
I reread your opening post. I'm not sure I understood it correctly.
You said,
"he needs one to be able to look into his camera down the lens."
Is your friend wanting to use the light in his photography, or is he wanting to examine his camera with the light when not taking pictures?
If he is wanting to use the flashlight for lighting while taking pictures, his most economical option will probably be a small incandescent light with a diffuser. The diffuser will give him a fairly smooth beam, and the incandescent lamp will give him good color reproduction. (If by chance he can find an incandescent light with a smooth, even beam without requiring a diffuser, that would be even better.
Generally speaking, LED emitters with a high CRI value (i.e., that will reproduce colors accurately) are not going to come cheap, and will most likely be out of your friends budget. Unless your friend typically only photographs blue objects, inexpensive LED lights won't be well suited for the task.
I'm not sure if Eneloop rechargeable cells will work well with most incandescent lights. I don't use AA or AAA cells with my incan lights, so I have no experience from which to draw.
If your friend is wanting to use the light to examine his camera when not taking photographs, there are many options suitable to the task.
As I understand the forum rules, linking to retailers' pages in posts is a big no-no, except in the Good Deals forum of CPFMarketplace.
