TOQ
I recently received the new version of the Olight M20, the R5-S. I have used the older R2 Premium now for over a year and was hoping for a bit more brightness and a further reaching beam, etc. I wish now I had just gone ahead and bought the M30 Triton as I am dissappointed in the overall performance of the new model M20. First off I must say the beam of light is of a whiter shade which I do like. Secondly, the extra "supposed" 70 lumen output is really stretching believability by big margin as the two beams side by side are almost the same in brightness. The R5 beam is wider and the bright spot is not nearly as concentrated as the one from the older R2. It does light up a larger area but beam throw is not what the advertising states it is, at least not to me it isn't. I much prefer the beam from the older R2 Th R2 has an advertised beam throw of 250 meters, the R5 shows 280 meters which is approx. 100 feet further. NO WAY does it throw that added distance. I live in a very dark area and have used both lights simultaneously to compare the beams and if anything the older version throws further. Both are fine lights, I have no problems with either one. I am just not pleased with the "hype" that goes along with many of these lights. I gave it a try, I am disappointed and I will use this as a lesson the next time I purchase any light. I think Olight, as well as the many other mfgrs. are missleading the consumers in both the lumen output and beam reach of their lights and this purchase made that very apparent to me. I am not into all the techno specs and stuff that many of you are but I can see what I see and I don't see much improvement if any in this newer version. I'd be interested to read any comments anyone else has about these two lights as opinions do tend to differ..............
