Hi, I just bought a semi-working LD20 original version. got an amazing deal from a nice guy
The main issue is that it cannot go into the 3 lowest modes. Every mode is almost the same brightness with turbo being SLIGHTLY brighter. Also, the turbo mode was very hard to engage into (required hard twisting).
I found out that the previous owner kept it in the car and as a result the batteries started leaking... i cleaned up the contact points with a file and now turbo mode is easy to get into.
Still cant figure out the mode problem...everything else works 100% fine...
I heard that using too high a voltage can cause a "direct drive mode" or something that bypasses the lower powers...but I'm using brand new eneloop 1.2v AA's.... I tried energizer alklaline AA's but same thing...
Any help much appreciated this is a great flashlight I want to get it working 100%
Vincent
Vincent
