Lumens Industry
Hello CPF :wave: I've been on this site for some time learning about this stuff and have built some lights for family and friends. Mags are easy enough to modify and there are many battery options available but I prefer the IMR 26650. So I decided to make a battery pack with this battery in mind. Charging is done with a 5.5mm jack and charger from Battery Space. I am willing to do a limited run to cover prototyping cost depending on interest. I've designed this pack to be modular so different configurations can be done. This is a single cell running with a TaskLED D2FLEX driver. Thanks for looking!
I have made a relief cut on the pack so it would fit inside the tail cap for shortest possible body.
components: housing, negative terminal, negative contact spacer, positive charging terminal insulator and positive terminal
deep spring mod is necessary for this light
I measured above 3.6 amps with standard leads
