KevinL
Hmm..... now that I am back in lighting and I have some time to spare I am thinking of building something crazy
I have a 4D Mag sitting around doing nothing, and I'm thinking of re-using the well-understood, safe 6xSubC NiMH powertrain that has served the ROP well for so many years. Easily good to 40W that the ROP requires, no problems here. As a bonus, this powertrain delivers the same voltage as 2 x lithium ion, making design much simpler (7.4V). We'll pull max 6A from a high-rate 3300mAH NiMH pack - slightly below 2C discharge even. The powertrain part I have settled, it's the reflectors/drivers I need advice for.
As for the front end, I'm thinking of using the quad-core LEDs, either 3-4 of them. I need a recommendation for a P7 reflector.
Plan 1 is to use 3 SSC P7's in series, but I need to find a good boost driver to get me to around 11 volts up from 7.4. Preferably one with a simple UI. 3 modes would be nice, 1 mode would be perfectly ok (ie. max blast!) and I don't want to have to rtfm to find out how to change modes on the light.
Plan 2 is not being able to find a driver, and going direct drive 2S2P. :devil: yes that smile is because I am perfectly aware of the thermal issues of driving 44 watts of LED in a mag head. I am only debating with myself, should I go nuts and go for a 2S2P setup or a far more tame (but more practical) 2S1P setup with just 2 LEDs in series? ie. do I want to build a flamethrower, or do I want to build a light that is actually useable without USL-style trigger locks! I'm already thinking I will have to store this one unloaded without its 6 NiMH pack lest someone accidentally get hold of it and cause thermal burns
Call me crazy, egg me on, give me advice: all welcome, bring it on!
