Well, I recieved my Zebralight SC50+ today. :thumbsup:
I would post some pics but for some reason (unknown to me)
I have a note on the bottom of my page that states:
"You may not post attachments". I'm sure it is somewhere in the agreement I agreed to but, who reads all that anyway? :thinking:
Anyone?!
Back to my story, as I was saying, blah blah blah.
It arrived in the typical plain, brown cardboard box that Zebralights come in. When I opened it the first thing I saw was the light. A cool little light it is.
An electronic side clicky switch with a light, but definite "click" feeling to it and a very slight audible "click".
The pocket clip acts as an anti roll..uh...thingy (..sorry I forgot how you guys refer to it) and attaches by screwing directly into the body. Very secure!!
The head has fins going around 180 degrees. I'm assuming they are to assist in dissipating the heat. Only two grooves (or one fin, depending on how you view it) are a complete 180 degrees. The remaining 6 grooves have a break (which form a "V") where the pocket clip is. I'm not going to try to measure the degrees but if you following the link above you see what I mean.
Even though it seems kinda bulky it is quite comfortable in the front coin pocket of my jeans. I could easily forget it's there as I go through my day.
I'll finish later, I have to ship a package to PA before the cut off time.
A day later:
Ok, after playing around with it last night, I definitely got a better idea of this lights purpose.
As Bowz3r says, a small task light.
After playing with another single AA (Inova X1, the replacement not the piece of cr&p I got from ebay) I expected a little more. I think an 80 degree beam is too broad for a "low" (I use this term loosely because I am still learning) powered light. At 25 Lumens the X1 is brighter than the SC50 at 41 lumens. I am only guessing but I think trying to spread that light over such a broad area diminishes the overall "preceived" illumination. I think a 60 degree spread with the stated 8.6 degree hotspot may be a closer to what I would consider "ideal".
The bright hotspot with a dim spread seems less than ideal. I also think a closer contrast would be more usable.
Also, The specs on Zebralight's site does not state it but my unit has a memory. At what ever sublevel you turn it off, when turned on it that mode, will revert to the sublevel it was on.
Example: When I turned the light on to 41 Lumens then double tapped the switch the light reverted to 21 Lumens. Then turn the light off with a single press and release. When I turn the light back on to the 41 lumen setting it, instead, went to 21 lumens. This happens even with the 5 or 122 lumens remaining at their level.
Does that make any sense?
Also, there is a delay when turning the light off. I prefer separate clicks to change levels. Having to make a mental effort to press, hold and count "1001" is kind of annoying.
It will take a little getting used to but I'll adapt.
It would be ideal if 4 Sevens makes a Quark side clicky switch light.
So far here's my list of pros and cons:
Cons:
Contrast and size ratio between hotspot and spread is a little too great.
76 degree spread is too broad (on lower power) for to be useful outside but works fine on full power.
The delay to turn it off. Hit the button and wait a moment to deactivate. Not good for stealth. My Ninja training did not cover that.
Non reversable pocket clip. They could have easily put a couple more tapped holes in the head and place a couple set screws it them to prevent filling with tiny foreign objects.
Pros:
Ergonomics: feels good in hand and in pocket. It goes away until you
need it. I probably look odd having to touch myself to make
sure I have my light in my pocket.
Side switch: this is my pocket light light, I like to remove it from my pocket and switch it on (at hip level) without the
finger yoga contortions required for a rear clicky. (Which I do like but for other purposes, which will be covered at a later date in a different post.
TailStand: It tailstands very well. I used it as a lantern in my closet lastnight and this morning on 5 lumens. The bounce off the walls lights up a small area very nicely.
Pocketclip: Very strong and secure. It would take a deliberate act to damage it.
With what's out there today, this light is a keeper. It will don my coin pocket daily.
I may or may not add to this subject as I notice additional aspects of this very nice little light.
10/27/10
Now I am convined the fins are for heat dissipation. This morning, inadventently, the light was on for about 45 minutes in my pocket. I pulled the light out and noticed how very warm it was. Not unbearable but very warm.
Anyone?!
A day later:
Cons:
Pros:
10/27/10
