Richie086
Hi forum,
I had the chance to get my hands on a retired, Julian A. McDermott handlight recently and felt you'd all appreciate how this project evolved to what it turned out to be. The fact it was used at one time by the New York City Fire Department, made it a must have for for this flashaholic.
This is a photo of what it looked like prior to being shipped
to me.
This is what the shipping damage was after our post office had it in their
possession for only 2 days. The ABS above the piano hinge was cracked and
the light housing, which is 1/8 thick ABS was smashed from its fixed position
mounting brackets.
The center portion between the cracked holes was also badly cracked.
The casing arrived with a large crack up the rear which also stretched
underneath the curve, not shown, right up to the base of the
NYC emblem. From the inside, if you gently pushed in that area,
the crack opened up 1/8. Incredible!
Two of the 3 screw ears that hold the bezel to the light housing
were completely cracked loose. I wasn't aware of this until
I unscrewed them to remove the 12v 50 watt Par 36 halogen,
which actually still worked.
The left side had no damage and was perfect.
I had a decision to make, do I simply discard it or try to fix
it? The Julian A. McDermott Corp. turned out to
be a very discourteous company and refused to respond
to my email requests, finally placing my email
address on their spam list after only two email attempts
to inquire about purchasing replacement parts or a brand new
handlight from them. Although I paid $64.00 for this light,
it's my opinion this company likely charges upwards of
$500.00 or more for this light brand new to Fire Departments,
Police, and other emergency service agencies.
Being a flashaholic, I decided to use my skills and rebuild it
from the ground up. The actual battery/hand box and PAR 36
light head are McDermott exclusive components, so it was necessary
for me to actually repair them rather than take the easy road and
simply replace, at least the light head, with a Grote brand head.
to me.
mounting brackets.
