Hello, I've been using a Wolf Eyes Explorer/Sniper as a handheld light for technical night-time trail running in the desert for about 2 years now. I use it along with a headlamp - I prefer both.
The pros of this flashlight, for my use, are:
* enormous hot spot, lots of flood. I don't like running with a tight bright hotspot in front of me.
* small enough to run with (well, more hefty than many edc lights, but still lighter than a water bottle).
* really bright, when needed - bright enough to investigate if an animal is seen within 50 yards (bobcat, mountain lion, etc)
The main problem I had using this light in AZ deserts, is that it simply gets too hot for continuous usage on high in the summer. Its also drop-in style design which I'm not fond of. So I would often have to use it on medium (the 30% setting).
The medium setting was OK for easy parts of the trail, but some technical spots I would want to use it on high, and it would immediately get too hot - and take a long time to cool down when returned to medium.
I'm looking for something modern of this size, or smaller, which has, most importantly:
* the same beam shape - described by Wolf-Eyes as "flood with medium throw", but its really just a large hotspot with the rest flood. The Explorer had an MC-E and a shallow reflector.
* using a newer technology, like XM-L i suppose
* good regulation on all settings, of course Should run at least 1 hour at 500 emitter lumens
* EXCELLENT thermal management, lots of surface area / fins. No drop-ins.
* have lots of preset brightness levels, or a system like JetBeams IBS so I can tune the brightness of the light for the ambient temperature in a way so that its as bright as safely possible without melting.
* single 18650 format.
* durable - I've fallen with mine in hand and crushed it
* smaller than something like an EagleTac M2.
The ambient temperature is often about 100'F.
btw, I also use a headlamp, but having a second beam (currently my Explorer) at roughly waist level is required to bring out details of technical trails, as well as the snakes
Thanks!
Thanks!
