ScaryFatKidGT
- Joined
- May 19, 2011
- Messages
- 918
Just got a 123^2 Turbo X direct from 4sevens. Its a lot smaller than I thought it would be even with the big head and it fits in my hand great. The beam shape is great for a smooth reflector and I like the big hot spot but it still throws. Most throwers have a smaller hot spot and I wanted a light that could light up a larger area but still throw and this is about perfect for that. At first I didn't think it was as bright as I thought it would be but its a lot brighter than my other lights. The pocket clip is basically worthless in the stock configuration because the opening to slip on to your pocket goes right up to the fins on the turbo head and doesn't leave any room and it isn't reversable unless you rotate the body 180 and put the tail cap and head back on then it works fine but it needs to be tightened really tight for the light to work and I'm wondering if its waterproof like this? The nice included holster is what I have been using and makes up for the clip mostly.
My main problem with the light I got is the tint around the hot spot and that it came with a chip in the anno on the head and on the flush turbo tail cap I ordered. On turbo and high the center hot spot is nice and white but it fades to a yellowish green color that looks like a pee stain or similar to the color of scorched paper. This tint is very obvious, no white wall hunting, I noticed it walking around at dusk in my front yard and in my car. On medium this tint sorta of goes away but then on moonlight and low its all green coming out of the thing. Should I try and return it? I have heard that 4sevens refuses to check tints for you, and even though it is bound to get chips I don't think it should ship with them.
