A couple of last minute "pre-build" questions before I start to
put this project together this weekend.. First off, the list:
1. Maglight 2D
2. 5700K SST-90
3. Britelumens SST-90 Heatsink
4. H6Flex
5. 6AA to 2D Adapter (Bought on CPF, using Eneloops)
6. Britelumens Reflector
7. Malibu Coconut Rum and Kahlua (50/50) on ice.
I have done a ton of searching & researching about this, but really can't find much about the following last questions I have...
Questions:
1. Do I need a resister in between the H6Flex and the SST? I guess after burning up my first SST-90 I am really paranoid about burning up another SST. I would rather avoid that obviously. My first build was identical only using a D2Flex, and with the 6AA-2D it burned it up as I had nothing in between the D2Flex and the SST. Oops. :sick2:
2. The Britelumens heat sink, on the back side as many of you know, is recessed, thus when you put the H6Flex onto the backside of the heat sink, only the outer edge of the H6Flex contacts the heat sink. Can I fill this void with anything to make better contact between the H6Flex and heat sink? I know I can have a spacer machined, but was hoping for other options.
3. Is there anything I need to do electrically other than just hooking up all the connections?
4. Is there ANYTHING else I need to worry about doing to this little project? I think I have it all covered though, but that might just be my ignorance.. :laughing:
I have all the standard stuff covered, thermal epoxy, thermal transfer goop, modifying the maglight switch, the booze, etc..
Any help/advice/thoughts will be much appreciated..
1. Maglight 2D
2. 5700K SST-90
4. H6Flex
Questions:
