Woah, the malkoff is expensive.
Is it that much better than the Terralux?
Lenny
The Malkoff is 260 OTF lumens.Woah, the malkoff is expensive.
Lenny
Malkoff make the best dropin for the maglite's, but I don't think he makes them anymore, he's always out of stock. A cheap alternative that is decent is this http://www.batteryjunction.com/tle-6exb.html Terralux makes another very bright drop in but 3 C cells won't power it.
I agree with ebow86 about spending a lot of money on a Mag Lite. That said, they do make great hosts and have a lot of room for copper heat sinks. I have a 3C Mag Lite that does just over 1000 lumens OTF and I just measured it at a bit over 90,000 lux @ 1 meter (measured at 10 meters and calculated back to 1 meter). Now that is a Mag Lite. You can't get that from a little AA light (or even a 2x 18650 light).
...that light you have there is an extreme example.
The point I wanted to make in my post was if someone is trying to spend less than $100 or so and looking for a decent light for real world useage, upgrading a old maglite isn't the best route IMO, not with the massive amount of affordable AA and CR123 lights out there today. Of course, if someone is looking for massive output and wants to spend some cash, like your example there, then yes, upgrading old maglite's is a good idea.
You said that Terralux makes another one that is brighter. I have a 3 D maglite that I want to convert to LED. Which one are you refering to? Will my 3 D battery power the one you are refering to?
Thanks, Shad
batteryjunction has a custom version of that module for 3D mags. The module, a battery pack made up of 5*1/2D cells and a special charger for the battery pack.Hi deal4, this is it http://www.batteryjunction.com/tle-300m-ex.html however, it needs at least 6 volts to run it (4 cell) and although it has the ability to run on alkalines, the performance will be poor.
In addition to the Terralux TLE-6EXB bulb from batteryjunction or led-replacement, superbrightleds have a couple PR2-1WHP-9V and PR2-3WHP-9V.
Hi all. What about a Mac's Customs Mag Drop-In? http://macscustoms.com/MagLiteDropIn.aspx 3 modes, hours of run time on high, days on low. $104 shipped in US. Am I missing something? It says up to 4 D cells. I assume 3 C cells will still drive it.
