i was in need of a new small task light for miscellaneous odds and ends at my workbench. after some consideration how well its smaller brother the streamlight microstream held up over the last 2 years of edc i decided i would buy the streamlight stylus pro. i got the light on ebay for around 20.00 USD shipped internationally (got it in 8 days so kudos to the seller) to my supprize i had recieved the newer version of the stylus. looking around on cpf i couldnt find alot of information on it so i decided to make this thread to help any potential buyers.
stats! i copied them shamelessly from the streamlight website as reference.
box contents:
the light comes packaged in a clam shell with easily open-able perforated back. inside the packaging there is the light, a replacement boothswitch, nylon holster and 2 batteries (energizer) already inside the flashlight.
initial impressions
upon playing with the light i have to admit; the newer tailcap is ALOT more dificult to press than the old version on my microstream. the complaints i read about this issue are sadly true, i find myself losing grip on the light as it slips down in order to activate the forward clicky. the booth mooshes up as you try to press down on the switch, it will switch on but wont 'click'. the light is significantly brighter than the microstream (pics further down below) its lightweight, bright and relatively small for what you get. the finish is a nice shiny light blue unlike the darker blue it showed on both the streamlight website and on ebay. its slicker than the darker anodizing on the microstream. as a result of this the pocket clip on the stylus can rotate around on the light without much force. it fitted in the pen pocket on my sleeve of my work jacket and its skinnier then any permanent marker i have laying around here.
getting sick of the clicky after 1 day of use i screwed open the tailcap of the light and cut myself a small plastic spacer out of the clamshell it came with. it improves the light alot, i can now turn it on and off with some pressing. its not as 'easy' as the predecessor (knowing how some people complained about that switch too) but i found it to be much easier after i did this. still the old switch had a long travel yes but it wasnt dificult to activate, newer version has long travel and is very VERY dificult to press, after the shim you still really have to press down on it. (going to experiment with thicker plastic in a few days, will report results)
size comparison:
i grabbed a ruler, few other flashlights and made some pictures. should be insightful enough for hopefully most flashaholics on here.
differences new vs old:
the main difference between the older version and the newer version boils down to 2 things. they upgraded the emitter from a 0.5 watt to a c4 led and they changed the tailcap so that the rubber booth can now be replaced by users.
(c4 on the left, 0.5 watt on the right)
(very clean cut threads on both the lights. never felt any grit in them)
(the newer tailcap disassembled)
being curious i tried switching the tailcaps between the 2 lights.
it looks hideous but yes it will work. this might be interesting for people who want to upgrade but not use the newer switch as they can move the switch from their old light over to the newer version without problem.
beamshots:
knowing how improtant beamshots are i tried making some. theyre not that great but again it might help any potention buyers so ill throw them out on here
(iso 1600, microstream old version on the bottom, c4 stylus pro on the top at 1~ meter)
(iso 400, microstream on the left, stylus pro on the right at 1~ meter)
i hope this helped anyone who was interested in the newer version. if you have any questions feel free to ask
- C4® LED technology, with a 50,000 hour lifetime.
- Unbreakable and scratch resistant polycarbonate lens.
- C4® LED (white): 1,033 candela peak beam intensity; 48 lumens measured system output; 6.25 hours runtime
- Powered by two "AAA" alkaline batteries (included)
- Push button tail switch – momentary or constant on operation.
- Tailcap switch for momentary on/off. O-ring sealed, shock proof and drop-tested construction. Water resistant per IPX4; in accordance with specification EN 60529:1992. Tear resistant nylon holster. Unbreakable pocket clip.
- L x D: 5.3" x .6" (134 x 15 mm)
- 1.64 oz (46.9 g)
- Matte Black, Silver, Blue or Red
box contents:
initial impressions
size comparison:
beamshots:
