Hello everyone,
I purchased an LD20 in November 2010 and discovered last night that the batteries had become stuck inside the flashlight. The batteries themselves are standard Energizer AA's that I loaded into the flashlight when I first bought it. I know they weren't expired when I first put them in, although I'm not sure if they are expired now because I can't take them out of the tube.
Several weeks ago, I noticed the flashlight wasn't turning on on the first click anymore. It would sometimes take up to 10 clicks to make the light turn on. Once on, the light was dimmer than usual for a given level of brightness. I will also add that the dim issue was seen a couple months before I started noticing the clicking issue. When I first noticed the dimming issue, I was able to remove the batteries. Changing the batteries for new ones fixed the dimming issue, although I decided to continue on with the old batteries because even the reduced level of light the flashlight was putting out was sufficient for most of my applications and I wanted to extract every last bit of value from the batteries.
Having said that, what do I do now? I've tried to jab the batteries out of the tube from either end, but they won't budge, and all of my jabbing is only making indentations in the battery. It seems I would be more likely to destroy the batteries further before I would be able to remove them.
Hopefully there's a fix for this. I would hate to think I spent $50 on an otherwise good flashlight only to have it ruined by batteries.
Also what exactly happened to the batteries? Did they explode inside the tube?
