Tiresius
So I got tired today and decided that I'm getting fed up with the cold white colors in some of my XML lights. Today, I was thinking about modding my Eagletac D25LC2 but had second thoughts. I want to ditch the U2 bin on my Crelant 7G5 V2 first so here we go...
The mod is fairly simple and does require that you be very delicate with the alignment housing and the emitter itself. On a scale of difficulty from 1 (newly started on flashlight with no knowledge) to 10 (very knowledgeable with circuit and electrical engineering), I'd give it a 4. Primarily because you need some soldering skills and patience. If done with haste, the plastic housing will crack and it won't align properly or look nice. Enough said, here's some photos
Here, we start with the light engine of the flashlight. Gentle must be applied when removing the plastic housing. It comes of with some resistant.
http://i707.photobucket.com/albums/ww77/zeron18/IMAG0355_zpsca21ecc3.jpg
Here's a side view of the whole unit.
http://i707.photobucket.com/albums/ww77/zeron18/IMAG0356_zpsbd1df139.jpg
After some soldering to remove the old one, I had to solder the newer one. It's a T4 XML (3,000K) temperature.
http://i707.photobucket.com/albums/ww77/zeron18/IMAG0357_zps173d9622.jpg
Now a mod is nothing without beamshots. Here it is compared to my Eagletac D25LC2 NW on a whitewall shot. Noticed how much warmer it is? That's the actual color I see.
http://i707.photobucket.com/albums/ww77/zeron18/IMAG0361_zps50546556.jpg
Your images are too large and have been replaced with links Please resize and repost.
See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Thanks Norm
