Eddie-M
- Joined
- Jun 21, 2010
- Messages
- 99
Hey CPF, I just wanted to show you a couple of my newest creations. You may remember these lights from this thread:
My ~1300-lumen mag 761 and ~10000 lumen mag 458.
Well, I cannabalized them into two new lights. Behold!
A 4D maglite and 6D maglite with JimmyM's JM-PhD-D1 PWM Hotwire Regulators.
The 4D maglite will drive a Philips 5761 for about 40 minutes on high at 1750 lumens.
The 6D maglite will drive an Osram 64623 for about 18 minutes on high at 8000 lumens.
The 4D uses fivemegas Bi-Focal Reflector slightly opened up with a step bit by about 2mm to fit the Philips 5761 bulb.
The 6D uses fivemegas FM3X Turbo Head.
The 4D uses fivemegas 12AA Battery Holder.
The 6D uses mdocods 21AA Battery Holder.
Here are the bulbs on waions high temp. sockets.
I did not use the standoffs on the socket for the Osram 64623 so I had to file the center hole just a little to allow the wires to not be pinched at the sides.
The holes to adjust the 11 turn pots for Vbulb and Vlow
I still want to stuff a little insulation down in there when I buy some.
I have the regulators set as follows:
(for Phillips 5761; 1,750 lumens regulated, 1,500 lumens cut off)
Vbulb: 7.6 Volts
Vlow: 7.3 Volts
Level-1: 18-100% (50%)
Level-2: 18-100% (75%)
Level-3: 18-100% (100%)
SoftRamp: Yes/No
Softstart: Slow, Med, Fast
Low Volt Warning: Pulsing or Dimming
Timed:# seconds, Undervolt: X%, or Both (Both, 30 Seconds, 94%)
VLOW_Latch: Enable/Disable
Over Temp trigger: 50C, 60C, 70C, or 80C
Over Temp Shutdown: Yes/No, If, Yes, Y seconds: (30 Seconds)
Response: 1/8, 1/4, 1/2 second
(for Osram 64623; 8,000 lumens regulated, 6,850 lumens cut off)
Vbulb: 16.2 Volts
Vlow: 15.5 Volts
SoftRamp: Yes/No
Low volt shutdown: Timed:# seconds, Undervolt: X%, or Both (Both, 30 Seconds, 94%)
Response:1/8, 1/4, 1/2 second
But to be fair I am still messing around with the low voltage cut-offs to decide what works best for me. The low voltage cutoff point can be above the bulb voltage point so I can have the the whole runtime be at maximum lumen output, and the point at which the batteries are 90% drained is still probably with a pack voltage above the bulb voltage anyhow, just need to test and find out where it is.
Here are the destructive incan tests for the Philips and Osram bulbs courtesy of LuxLuthor.
Driven at 7.6 Volts for 1750 lumens
Driven at 16.2 Volts for 8000 lumens
Beamshots to follow shortly
Vbulb: 7.6 Volts
Vlow: 7.3 Volts
SoftRamp: Yes/No
Vbulb: 16.2 Volts
Vlow: 15.5 Volts
SoftRamp: Yes/No
