Sold/Expired 7* XM-L U2 FiveMega Elephant II host: 7000 Lumen *BIG Pricedrop: 549$ Shipped WW*
Epsilon
Netherlands
*SOLD* 7* XM-L U2 FiveMega Elephant II host: 7000 Lumen
For sale:
*Again for sale on CPF custom! *
*SOLD*
My latest build: Fivemega Elephant II with 7* XM-L U2 on copper-PCB, driven by a taskled HBFlex driver @ 3000mA.
Link to build-thread
Selling to free up funds for new builds.
In short, this light is very, very impressive in output. Built with some of the best components available to create a high quality light, which is actually usable. Not really happy to see this go since it's my biggest build yet, but some things just have to be done :).
- FiveMega Elephant host
- 7 * XM-L U2 on the more than excellent Led-tech.de copper boards
- Taskled.com HBFlex driver, to drive the leds
- Huge chunk of aluminium heatsink
- Momentary maglite switch
- 7 Der Wichtel reflectors
For sale for: 899$799$749$719$699$669$599$549$
This includes insured worldwide shipping.
This includes the custom batteryholder for 4*18650 cells.
This excludes the batterypack. Add 50$ for the battery pack.
First I'll take it in this topic with prompt payment gets it :).
(Pictures are clickable)
Beamshots!
Control shot (1sec exposure)
35mm OP reflectored XM-L T6 light @ 2800mA on standard alu star (taken on a different day with the same camera settings, but put here to put the other two lights into perspective):
Maglite Rebel with XM-L U2 on copper Led-tech board @ 5A:
And the 7* XM-L U2 Light of this topic :D :
Comparison detail:
So due to it's shear power, it outtrows the very impressive Mag2D Rebel :D.
Runtimes
Code:
Runtimes on 4*1600mA 18650IMR = 23.7Wh:
 - 3000mA ~ 77W ~ 7000lumen ~  18min (Max mode)
 - 1000mA ~ 24W ~ 2800lumen ~  55min (not an actual mode, just for runtime perspective)
 -  350mA ~  8W ~ 1000lumen ~ 180min  (not an actual mode, just for runtime perspective)
 -   50mA ~  1W ~  150lumen ~  24 hours     (Lowest mode)
Battery holder:
Code:
Voltage cut-off settings:
16.8V  4.20v (full)
13.6 3.40v (medium)
13.0 3.25v (Low)
12.0 3.00v (Cutoff)
Temparatures, measured with 3A drivecurrent
(On table, no airflow, measured on neck, where the heatsink touches the neck. Sensor with AA).
Secs DegC DegF
  0 20.9 69.6
 30 21.4 70.5
 60 22.9 73.2
 90 24.7 76.5
120 26.5 79.7
150 28.4 83.1
180 30.2 86.4
210 31.9 89.4
240 33.6 92.5
270 35.2 95.4
300 36.7 98.0
Size vs Mag2D:
One note I would like to make is that the tailcap has an imperfect finish and is not the same color (greenish tint). This can be seen in this picture:
To me it is not a problem, since it is barely visible in most circumstances and I use it to set the light down :), but have to note it.
BeastFlashlight
Boston
Re: WTS: 7* XM-L U2 in FiveMega Elephant II host: 7000 Led-lumen power
What are the dimensions and on full blast how long can it run continuous before getting too hot?
Epsilon
Netherlands
Added temperature measurements (and calculated them to DegF while I was at it).
So it will run continuously from room temperature for 5 minutes easily. I think that the TaskLed driver has a temperature cut-off, which I can program in if it has :).
edit: Added picture vs Mag2D for size:)
Epsilon
Netherlands
Pricedrop and added 4*18650 battery holder :)
Epsilon
Netherlands
Friday bump. Now 799USD shipped worldwide including the battery holder , without the batterypack.
849USD shipped worldwide including the battery pack.
Epsilon
Netherlands
Pricedrop to 749$ shipped!
Epsilon
Netherlands
Pricedrop to 719$ Shipped!
And up for sale again here on CPF Custom and modified!
CaptainBrock
May I express appreciation for your most impressive work. I would really like to see this design implemented as a marketable production supported by an established manufacturer. Some confidence for safety are reliabiability are needed. I could personally justify funding at the 500 USD point for such a prize possesion!
Stay well,
Captain Brock
:eek:
Epsilon
Netherlands
Thanks you :). 500USD would be sweet if they made it available for that price indeed. But sadly, the parts on this build alone exceed this amount heavily :(.
Epsilon
Netherlands
Reduced to 699$ Shipped worldwide!
Epsilon
Netherlands
Bump!
Grab it before it drops below someone's threshold so one else does ;).
darkangel55555
Melbourne, Oz
Just as a cautionary aside, you shouldn't be mixing cell brands in that pack, especially with that much of a power draw.
Good luck with your sale!
Epsilon
Netherlands
Thanks for the reply :). You are absolutely right. I didn't have 4 identical cells for the picture so used some cells I had lying around.
Epsilon
Netherlands
Friday (saturday in NL) pricedrop to 669$ Shipped!
Epsilon
Netherlands
C'mon guys you are killing me here :(.
Pricedrop to 599$ ensured shipped worldwide!
