FresnelMag4
Hi CPF, it's been a while!
Anyway, I'm starting a modification to my 6D maglite. My plan was to do the ROP mod, allowing the 6 cells to do the work. I'm waiting for the lamps and SMO reflector to arrive in the mail, and I think I'll cut the lens myself from 1/8'' plate glass. ( I know borofloat/UCL lens' are cheap, but so am I ) Now for the $64K question(s): I'm gonna use alkalines until I can find reasonably-priced NiMh D-cells, so how much runtime can I expect, and will I blow the lamp at 9VDC as opposed to the 7.2 VDC of rechargeables?
Also, if alkys are feasible (at least for now), should I add a series resistor to lower the lamp's voltage, or will it (the Pelican 3854) do alright on 9 volts?
Thanks!
EDIT: Another option: I have a 2C mag, if you could suggest cheaper rechargeables.
Thanks!
