kj2
*picture heavy*
I have the PD35 almost a week now. And I thought, let's make some pictures (sorry for the dust on my lights )
Specifications of the Fenix PD35:
- Cree XM-L 2 (U2) LED with a lifespan of 50,000 hours
- Digitally regulated output - maintains constant brightness
- 5 Brightness Levels Plus Strobe
Turbo - 850 Lumens - 1 hr. 30 min.
High - 450 Lumens - 2 hr. 30 min.
Mid - 170 Lumens - 7 hr. 45 min.
Low - 45 Lumens - 29 hr.
Eco - 10 lumens - 140 hr.
- Low-voltage warning function to remind you to replace the battery
- Reverse polarity protection guards against improper battery installation
- Over-heat protection to avoid high-temperature of the surface
- Anti-roll, slip-resistant body design
- Tactical tail switch with momentary-on function
- Side switch on the head
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- 139.0mm (Length) x 25.4mm (Diameter)
- 87.0-gram weight (excluding the battery)
I like the PD35 over the PD32UE. Mostly because it uses a Cool White emitter instead of a Neutral White.
With the PD35 you have a wall of light in front of you, when you have it in Turbo-mode. The light does get hot quickly,
so don't run in to long
