EvilBlackDog
- Joined
- Aug 23, 2013
- Messages
- 3
I would like to create a UV curing light to trial some UV sealants. Like the thread title says, the spec for the sealant says they cure in the 365-420 nm wave length range. I was thinking that it would be neat to build it into a flashlight housing but isn't totaly necessary. I need something powerful to do the job, sure the standard 5mm led's will cure it but it will take a long time. Does anyone have experience building something like this or could point me in the right direction?
I read another thread that talked about using a Cree 7090 UVV which is in the correct wave length range but I couldn't even find a place to buy them. Plus they don't seem to come in the standard configuration that I see most of the LED's used for flashlights come in.
I'm just looking to get pointed in the right direction, thank you all in advance.
