kj2
As far as my info goes, Fenix will announce tomorrow the following products;
- TK51 - http://www.candlepowerforums.com/vb/showthread.php?361483-*new*-Fenix-TK51
- HP15 - http://www.candlepowerforums.com/vb/showthread.php?252231-Upcoming-Fenix-Headlamp-HP-15/
- ARE-C2 charger - Will charge Li-ion and Ni-MH rechargeable cells. Charging four different rechargeable batteries simultaneously, LCD display will keep you informed on the voltage and charging status.
- ARB-L2S (3400 mAh)
HP15:
Specifications:
- Cree XM-L2 LED
- Digitally controlled
- 5 light modes / 1 special modes
Turbo : Max. 500 lumens / 2 hours with Ni -Mh / 1.5 hours with alkaline
High : 275 lumens / 4 hours with Ni -Mh / approx 3.5 hours with alkaline
Mid: . 125 lumens / 10 hours with Ni -Mh / about 14 hours with alkaline
Low : 45 lumens / 25 hours with Ni -Mh / approximately 220 hours with alkaline
SOS 125 Lumen
- 50,000 hours life
- Waterproof IPX 6
- Operation with 4 AA cells , either NiMH or alkaline batteries
- Dimensions : Lamp head : 67.4 mm (length) × 55.9 mm (width ) x 43.8mm (height)
- Battery : 88.8 mm (length) × 73.7 mm (width) × 26.2 mm (height)
- Weight: 162 grams without batteries / rechargeable batteries and without headband
- Electronically regulated for constant brightness largely
- Lockout feature to lock against unintentional start
- Removable diffuser lens
- Extension cable to carry the battery compartment on the body can
- 60 degree setting angle of the light
- Protection against Inserting batteries in the wrong direction
- Made of high quality aluminum and plastic
- Ultra clear lens with anti-reflective coating
TK51:
- Cree XM-L 2 (U2)
- Digital control maintains constant brightness
- 50,000 hour life of the LED
Spot&flood led
1 LED:
Turbo: Max. 900 lumens for 3 hours 30 minutes
High: 400 lumens 9 hours
Medium: 150 lumens 27 hrs
Low: 10 lumens 420 hrs
2 LED:
Turbo: Max. 1800 lumens for 1 hour 45 minutes
High: 800 lumens 4 hours 30 minutes
Medium: 300 lumen 13 hours 30 minutes
Low: 20 lumens 210 hrs
- Strobe 1,800 lumens
- Intensity: 45200 (Max)
- Light distance: max. 425 meters
- Length: 18.8 cm, Body diameter: 4.8 cm
- Weight without batteries: 430 grams
- Hard-anodized surface
- Waterproof gem. IPX-8 = 2 meters for 30 minutes
- Specially coated lens
- Powered by 3 x 18650 Li-ion Battery
ARE-C2:
- Input: 100-240V (AC), 50/60Hz, 500mA (max)
- 12V-24V (DC), 2000mA (max)
- Output: 4.2V (DC), 1000mA x 4/4 x 500mA
- 156mm x 99.5mm x 37mm (length, width, height)
- Weight 275g without batteries
HP15:
Specifications:
- Cree XM-L2 LED
SOS 125 Lumen
- 50,000 hours life
- Waterproof IPX 6
TK51:
- Cree XM-L 2 (U2)
Spot&flood led
1 LED:
2 LED:
ARE-C2:
