I love these copper mule sinks. I have been using larger head - Z32 / KL3 to enable a reflector. With LED on copper sinkpad, on large copper heatsink, thermal management is so good.
So what about the poor old 7135 chips?
I made a 3mm thick copper disc with cutout for positive, ran the negative wire through the centre. Took 4 separate mixes of arctic silver to complete the bottom section. Happy with the result, looks neat and now chips not only have a heatsink, the heatsink has good thermal path to mule sink.
So what about the poor old chips on the top?
This is where I knew it was going to get ugly. I needed a thin copper sheet to extend the heatsink around the driver and then epoxied thin copper sheet to top of chips.I went around the edge and pushed the edges together and section where no sheet on top got bent down onto negative ring of pcb.
Then soldered the copper side and top together.
Not pretty now, but all chips have thermal path for heat and whole thing is potted.
The driver sits proud of the resess in bottom of mule sink (therefore need for copper to extend) but it still goes all the way down in the FM 6P host.
Just put a Z44 bezel on to test function,temporary mule. It will be getting a reflector. Wires to lEDS have a bend for bit of spare for future LED replacemnet if I want. LED is screwed down with thermal compound, not epoxy so easy maintenance.
Surprised how much room there is to spare, I might try similar mod but with 3mm copper disc on top too...
