Labrador72
It seems Fenix is releasing colored filters for the PD35, PD12, and UC40 (25.4) but on their website it says it's compatible with the PD32 UE (24mm) so unless it's an error, it must fit the PD32 and PD31 too!
It's probably not an error. I have the diffuser that came with the PD32UE. I think its the AOD-S. Anyhow it has an inside taper so that it also fits the LD12/22. It just slides on further onto those lights. So I'd think if it will fit the biggest diameter light, it will then fit the smaller diameter lights.
After I started this thread I noticed Fenix updated their website and removed the PD32 UE so my guess is that they only fit the PD35 and UC40 but none of the other lights with a smaller head diameter such as PD31 or PD32. If you want to be dead sure send a mail to Fenix.
Has anyone tried fitting one of these filters for the PD35 onto the PD32 or PD23UE?
It looks like the PD35 is noticeably thicker. Specs for the filter say 1.16" which is 29.464mm...most likely outer diameter.
