SCEMan
While walking tonight I started wondering how a reflector's diameter affects brightness :thinking:
For example, two flashlights with identical drivers/leds.
#1 - a P60 size bezel & standard OP reflector
#2 - a larger diameter bezel & similar design OP reflector
#1 throws a fairly wide beam, #2 throws a much wider beam
Both have equivalent throw/lux, the diameter of the beam is the only difference
Both are putting out the same lumens (compare w/o reflectors), would #1 appear brighter (actual or perceived) than #2 since the wider reflector is dispersing the beam across a larger area?
In other words, does the more confined beam area of #1 appear brighter when compared side-by-side to #2?
I lack two lights with the above characteristics to test, and wonder if anyone has observed whether this actually
occurs and if so why?
Thanks for the feedback
