The simplicity is easy and yet, I have problems with some as they age. For instance on the the Peak Eigers and those before them. At some point, the foam spacer deteriorates and about that time, the light ceases to work. Peak has sent new bodies and I've bought spares. I don't understand why this happens. I don't need blazing output, just enough to put sufficient light out for up close tasks in dim places. These Peaks lights are fine. The Peak head works on other Eiger bodies so the head is fine. I tire of the body replacement.
I've attempted to clean the lower contact, rough the surface up for a better contact...fail. What is causing this? Is there a simple fix for me to attempt?
