Solarforce flashlight
SkinnyCow
Anyone is familiar with this brand? The way they advertise is some what confusing. I'm not sure if I'm buying a flashlight or parts and I need to assemble them. Is this a complete assemble flashlight? Solarforce L2M 3 mode XM-L2 U2 cree led 980 Lumens BLK Flashlight
http://www.solarforceflashlight-sales.com/product_detail.php?t=LF&s=56&id=584
Also, does anyone know the beam intensity of their light. Their lumen seem high but with low intensity, it'll not be perceived as bright. I want high beam intensity.
Thanks in advance.
kj2
The Netherlands
This is a body and drop-in, so yes, a 'complete' flashlight. For more info about solarforce I suggest you take a look in the 'budget-light'-section :)
GeoBruin
Los Angeles, CA
The L2m is a p60 compatible light which means it accepts a drop in module as mentioned above. The XM-L2 LED has a relatively large die and in a P60 size head, it will not be able to achieve a very high intensity.
If Peak beam Intensity is what you're looking for, you should look at some of SolarForce's other lights with larger heads or look at a p60 light with a smaller led like the XP-G2 or XR-E2.
