jtice
Just got one of these the other day and just had to post about it, one of the better lights I have got in a while for the price.
Supernova Halo 180
Really cant find much info on it, I think its a fairly new light though. There is also the Halo 130, which runs on 2AAs.
The Halo 180 has a 1800mAh li-ion cell built into it, it is not replaceable. It charges via micro-USB.
180 Lumens on high (hence the name Halo 180) (the Halo 130 is 130 lumens)
5 Modes: High, Medium, Low, Slow Flash, Fast Flash
Magnetic Base
Fold out spring hook
The first press of the switch (which is fairly recessed, should be fine in a pack) turns on a dim indicator led, green= charged, red= needs charged.
I am still doing some testing, but last night I ran the light on high for over 3 hours and the indicator still showed green.
I think I read somewhere that you can expect about 4 hours on high.
The tint is great, its a slightly warm/neutral tint. Very pleasing to the eyes and it has a perfect flood with no artifacts.
The light barely gets warm even after hours of continuous use on high.
Magnetic Base is pretty strong, I had no issues getting it to stick to lots of metal surfaces. Though it will slide just a bit at times since the surface of the light is just smooth plastic.
I had it stuck to one of the metal rails on my homes drop ceiling. Worked great, lit up the room with a very even flood of light.
Hook seems a bit on the flimsy side, but still very functional as well.
Overall I really like this light. I think its a great value for the money. It can be closely compared to the new Fenix CL20, which cost about $40, the Halo 180 is $25.
I will get some photos of the light in the next few days.
Supernova Halo 180
Magnetic Base
