Hi,
I have LED Low voltage Techlight tree fixtures with Constant Current LED Drivers that recently got struck by lightning! blew all my LED drivers and some of the LED chips in the fixtures! I purchased new LED chips to re-solder into the light fixtures. They are BRIDGELUX BXRA-C2002 2200 lumins. Here are the specs from the bridgelux spec page > Maximum DC Forward Current (mA) = 2,500 / Minimum DC Forward Current (mA) = 750 / Forward Voltage was like 16.5 at 1500 mA (or) 15.6 at 1050 mA.....I purchased the Drivers from "Mean Well" they are LPC-35-1050 / Input 100-240vac / 1.1Amp / 50-60Hz / Output + 30v / 1050mA max. I hooked up one of the new LED's to the new transformer and all was well! But after roughly an hour I noticed the fixture was pretty hot! And I do not know if this is normal as I have just basic knowledge of these systems. The system was originally installed by a low voltage landscaper guy. He ran one Driver per fixture. I did spend several days researching the LED's and Drivers but started to get confused by the wattage? ( Hoping I did not purchase the wrong Drivers!!) On the LPC-35-1050 the 35 stands for 35 watts, but the Bridgelux LED specs say nothing about wattage? (that I seen) They do make an LPC-20-750 that produces 20 watts. But the original drivers where 1050 mA which is why I chose the LPC-35-1050 but I did not take into count the wattage difference of the two. I did pull out my voltage tester and the DC output side was reading around 14.6-14.7 (If I had it on the right setting) I just do not want to burn these new LED's I bought up...I had a misc driver I hooked up to the fixture ( WH-L241-700 / PRI: 120Va.c. 300mA., 60hz. / SEC: Max. 42vd.c., 700mA) and it ran much cooler, but is less DC output than the bridgelux led calls for according to the spec sheet at bridgelux site ( Minimum DC Forward is 750mA.....Hopefully one of you guys can help me out here? Many thanks in advance for any help!!
