Painkiller7
So I originally going to get a Zebralight H600fw mk2 but decided to get a decent flashlight instead and keep getting by with my Petzl Tikka plus until I upgrade headlamps down the road. I've looked at a plethora of reviews in this forum and am mainly looking at the Thrunite TN31 and TN35.
Ideally I want a light that has a fair amount of throw with some spill to light the surrounding area. It will be an all around light to piddle with, check for things that go bump in the night, check the area I'm in, search and rescue, and if possible use in structure fires.
I'd like real world advice when a particular light is suggested. I know I probably can't get everything I'm after with my budget at the moment, so search and rescue/fire lighting is going to be the primary objective. All help and knowledge is greatly appreciated! American made is a plus!
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X_This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
____Up to $25.
____Up to $50.
__X__Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
__X__MEDIUM - Holster/belt ring carry. (>7 inches)
__X__LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__X__I want search and rescue type illumination (800+ lumens).
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X__Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
__X__30-50 yards/meters (I have a big backyard)
__X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
__X__150+ yards (I am searching from a helicopter)
__X__30-60 minutes (I have plenty of batteries just ready to be changed)
___X_90-120 minutes (Runtime is moderately important, but still not critical)
___X_3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
__X__Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
__X__I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__X__I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
__X__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
__X__Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
__X__Red filter (for preserving night vision).
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
____Up to $25.
____Up to $50.
__X__Up to $100.
____Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
____I don't care
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
__X__I don't care.
____I don't know.
____None needed
____Holster
