lampeDépêche
- Joined
- May 15, 2012
- Messages
- 1,241
When I was a kid (before you were born), my Dad had a lantern that screwed on top of one of those big old 6v batteries.
The battery was not the square-top 6vs with the two conical spring-connectors. More like two of those side-by-side, a big rectangular block, with two threaded terminals.
I learned today that the battery size is called a "4LR25-2".
So this light was all sheet-metal (plastic had hardly been invented yet!), had a white spot-light up front with maybe a 10cm reflector on it, a red dome on the back, maybe 3cm in diameter, and I even think it had some sort of amber blinker in the middle, though I can't picture that for sure. Of course it had a carrying-handle in the middle, and each of the lights on front and back were on pivots to direct them up or down. Naturally this was a light destined to spend most of its life sitting on the ground--too heavy to carry for long!
And it had a sheet-metal base-plate that fit over the screw-terminals, and was attached by the nuts that threaded down onto them. (Looking back on it, I now realize that the base-plate had to have two pieces of metal that were insulated from each other. In my infant mind, it was just a large sheet of metal that fit on top of the battery. But that obviously cannot be right).
Anyhow--anyone out there remember these? Have one? Have photos?
I did a Google Image search, but no luck.
My guess is that I have AAA lights that would outperform this thing now. But when I was a wee lad, it certainly seemed impressive. And it was surely one of the steps on the road to perdition, i.e. to my present state of depraved addiction.
