jon_slider
- Joined
- Mar 31, 2015
- Messages
- 5,163
Note, I started this thread thinking 10440 should not be used in a 1.5 volt light such as the Lumintop Copper Tool. But thanks to several people sharing experience of no damage, Im not so sure 10440 is as problem prone as I initially believed.
Educational links
Making Lithium-ion Safe
Charging Lithium-ion
Lithium-ion Safety Concerns
Using Li-ion cells in LED flashlights safely
disclaimer, Im a newbie, no 10440 experience...
I have Safety concerns about using 10440 in a light rated for 1.5 volts. imho people who want to use 10440 should do so with lights that have drivers rated for the voltage, and protection circuits, and/or use protected batteries.. I recommend V54 Lights - Sky Lumen for custom LiIon driver upgrades.
I started this thread because I did not want people to ignore manufacturer warnings to Not use 10440 in 1.5 volt lights. As I learned more, I started to want to know how people who actually have been using 10440 for a long time, do so safely. By Post #13, I was considering using 10440, though Im still on the fence because of warnings not to leave chargers unattended overnight..
reasons not to use unprotected 10440 in unprotected lights not rated for 10440:
quoted from here:
"One detail that I would make clear is that, according to the manufacturer, the use of 10440 batteries will damage the flashlight irreversibly." Note, this factory claim contradicts several users reports of no damage to their Lumintop Copper Tool.
and here
link
fwiw, the Eagletac D25aaa can be had with N219 and is rated for 10440.
Educational links
quoted from here:
and here
Why putting an IMR10440 in a regular AAA light is bad:
link1. LED mounted on aluminum MBPCB/Heat sink. Aluminum sounds good but the LED actually sits on an insulator layer which doesn't relive heat from the LED fast enough when over driven with a IMR10440.
2. Circuit components are typically rated about 2V to boost max efficiency. When you put in 4.2V things goes into direct drive and all sort of things like transistors can overheat and go. Power=Current*Volatge, A linear relation, Upping voltage surpasses the max power handling of all parts and they will inevitable fail. Note, several users report no damage to their Lumintop Copper Tool.
3. If the components do not fail completely their specs will change over time and thus you can not go back to AAA anymore. Note, several users report no damage to their Lumintop Copper Tool.
4. LEDs life dramatically reduced due to unrelieved heat
5. LEDs can de-solder itself with heat
6. High heat at the LED = current inefficient flow = lots of heat = brightness loss. Current must flow smoothly to keep heat and thus resistance down.
Those are some reasons that came to mind.
DriverVN2 is user programmable making a AAA size light incredibly comprehensive but flexible. LED mounted on copper gets heat away from LED right away, no bottle necks. The more heat you feel is the less heat the LED have to suffer. Extra copper HS adds heat capacity. DriverVN2 has a great track record. Sold many hundreds with very little issues. And when there are issues its usually just my fault not the circuit.
DriverVN2 & DriverVNX2 are continuously being upgraded with improve parts. Although never officially announced.
linkI will not be doing a ToolVN Ti run. I will only have copper and Aluminum. Thanks!
Note, several users report no damage to their Lumintop Copper Tool.emarkd said:Its been pointed out to me that this light was never meant to support 10440 and they could quickly damage these lights. I know of at least one that now has a destroyed boost driver because of trying to use 10440, so it'll no longer function with primaries or eneloops.
link
jon_slider said:Tools are not rated for 10440 voltage but:
Note, several users report no damage to their Lumintop Copper Tool.jon_slider said:http://www.fstoplights.com/lumintop-tool-copper-xp-g2-r5-110-lumens-limited-edition-aaa-flashlight/ says
"10440 supported
The Tool AAA Copper unofficially supports 10440 lithium cells - for super-output (up to 250 lumens)
Do take note that once 10440 is used for a long time - the Tool AAA may not work on normal AAAs again"
