jayflash
I've used three headlights for XC skiing and machinery maintenance for the past 15 years. They are all old-tech incans, one is a 4D belt carry, one is dim and intermittent, and the last one broke. The large, 4D light is good quality and nice for extended run-time, but too big for comfortable skiing use. The other two were bulky when carrying in the pocket when not used, and too breakable when suffering (too numerous) skiing crashes.
Now I use a NiteIze or my homemade headband which will accept a variety of flashlights, such as: Arc AAA, Arc LS - 123 or TSP, Scorpion, MiniM*g AA & AAA, TT-1 & 2 etc. The homemade band came from the broken headlight and has a patch of velcro, 1"x2", sewen to each side, above where the ears are. A smaller and larger 2" wide elastic loop was sewn to either of, two, mating pieces of velcro. This allows the secure use of thin (AAA) or thicker (Scorpion) barreled flashlights, or one on each side. The velcro also allows adjustment for best beam spot, either right in front of you or further ahead. A split ring was sewn behind the velcro patch to attach a lanyard from the lights. This will keep the lights from falling into the snow and possibly getting lost.
This arrangement is less bulky when stored in the pocket and the flashlights are more rugged than headlights. This also allows for customizing your lights for the particular task. I suppose others have discovered this idea years ago but it's new for me. Thought I'd pass it along and ask if others have suggestions for headlamp solutions.
