kj2
In this review, I take a look at the Rofis TR20. Some may have heard from Rofis, but it's a relativity unknown brand in the flashlight market. But unknown doesn't mean that it's bad.
It was my first take on a Rofis light also. Did know the brand but never saw or handled one before. The TR20 looks like a standard flashlight like any other, but it has a adjustable-head which gives
you the option to make it an angled flashlight. Kinda cool if you ask me
The TR20 uses a Cree XP-L HI led which has a max of 1100 lumens. Combined with the smooth reflector, it has quite some throw. Besides the adjustable-head, it also features a micro-USB port for charging.
At the back of the light, you'll find a removable magnet for heads-free operation.
The packaging:
The Rofis TR20 comes in a colored cardboard box, with specifications and highlight printed on.
Inside the box you'll find; the TR20, included Rofis 3400mAh 18650 battery, Magnet tail, Pocket clip, Holster, Lanyard, 2x o-ring, spare USB-port cover, USB charging cable, manual and warranty card.
A close-up look on the included Rofis 18650 battery. The cell is from an unknown supplier.
Features and Specifications: (given by Rofis)
- Adjustable-head for multi-functional useage
- Detachable magnet tail
- Cree XP-L HI V3 led
- Max output of 1100 lumens
- Peak beam intensity of 10850 cd and max throw of 206 meters
- Single button access to six brightness levels and three special modes
- High efficiency constant circuit, provides max runtime of 200 hours
- Integrated power indicator light displays remaining battery power
- Power indicator's secondary function displays battery voltage
- Charging module with micro USB-port to charge li-ion battery
- Direct access to ultra low or ultra high output
- Reverse polarity protection
- Constructed from aero grade aluminum ally with HAIII hard-anodized finish
- Waterproof in accordance to IPX8 (2 meters submersible)
- Impact resistance to 1.5 meters
- Tail stand capability
Price: ~ $80
The TR20 looks like a 'standard' light, if you're looking in a hurry. The slots at the head aren't just for affect. They also show where the head twist to make it an angled flashlight. Those slots line-up
perfectly when twisted. The clip can only be placed on one place, which allows for head-up carry. At the tail is the removable disc that holds the magnet. The disc uses a screw to be attached to the light.
When the magnet is not placed, there will be a screw-hole visible. This will not interfere with the water-resistance at all.
Just below the head is the micro-USB port to charge the light. It uses a rubber cover to prevent water and dust coming in. Do make sure the cover is pushed all the way in during use.
Out of the box it did require to much force to twist the head. It was almost impossible to twist the head back and forward. After applying some Nyogel it became much easier to twist.
Maybe it just need some break-in, but I think Rofis have to look at this closer. The corners, that occur when half-twisted, aren't that sharp as they may look.
The TR20 has square-cut threads that aren't anodized. The threads aren't anodized because of the charging feature. A single o-ring should keep dust and water out. The was no lube applied on the threads.
Dual springs help with shock absorption.
While charging, a red led will be visible. When charging is finished, a green led will be visible.
The red led will also indicate when battery power is running low and needs to be charged.
User Interface:
The TR20 has two switches. A On/Off switch and a mode switch.
To turn On or Off, press the On/Off switch. To cycle between the modes, press the mode switch.
This will cycle between: Moon (5 lm) > Eco (10 lm) > Low (80 lm) > Mid (280 lm) > High (500 lm) > Turbo (1100 lm)
The TR20 has brightness mode memory, and will turn On in the last mode used.
While Off, press and hold the mode switch for 2 seconds to enter Moon mode. Press and hold the On/Off switch for 2 seconds to enter Turbo. (memory will not work in this UI part)
When On, press and hold the mode switch for 2 seconds to enter the special modes. Press and hold to cycle between Strobe, Beacon, SOS.
Indoor Beamshots/ Outdoor Beamshots:
ISO400, f/5.6, 1/25 sec - Canon 500D - Light approx 30cm/ camera 1m in front of wall.
ISO400, f/5.6, 3.2 sec
TR20:
Turbo
Surefire P1R Peacekeeper:
High
Zebralight SC600w III:
H1
Size comparison:
(From L to R; Rofis 18650, TR20, ZL SC600w III, Olight R20, SF P1R)
Pros and Cons:
+ Angle option
+ Included battery
+ In-light chargeable
+ Removable magnet
- Head twist require much force
- Twist durability over time.
Conclusion:
The TR20 is somewhat in his own class. That's because it has a feature which you don't see that often. The adjustable head feature is something most manufactures don't do.
It gives the light more user options and together with the removable magnet, it may suit or needs very well. But at the end, is it durable enough? Time will tell.
Modes are well spaced out although I didn't notice much difference between High and Turbo. The micro-USB port is a great bonus as well. Same applies to the included 18650 battery.
With a price of around $80, it isn't that bad at all. You get a all-in-one package and don't have to buy extra's before you can use the light. At the end, I'm satisfied with this light and expect it will get
used in- and around the house.
The Rofis TR20 was supplied by Bensnail for review.
The packaging:
Price: ~ $80
User Interface:
TR20:
Turbo
High
H1
Size comparison:
Pros and Cons:
+ Angle option
+ Included battery
+ Removable magnet
Conclusion:
