HKJ
[size=+3]Keeppower 18650 3120mAh P1831R (Black) 2017[/size]
Official specifications:
A protected battery that can deliver a lot of current and has good capacity.
The discharge curves tracks very fine.
The B battery jumps a bit in voltage, it looks like a loose connection in my test setup.
A full discharge at 15A is a bit much for this battery, it gets rather hot. I had to stop one of the discharges.
At 15A I had to stop both discharges due to temperature.
[size=+3]Conclusion[/size]
This is a good cell, but the build in protection do not trip on overload (It will probably trip on higher currents).
[size=+3]Notes and links[/size]
The battery was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Part No.: P1831R
- Protected 18650 Li-ion Rechargeable Battery
- Minimum Capacity: 3000mAh
- Typical Capacity: 3120mAh
- Normal Voltage: 3.7V
- Maximum Continuous Charging Current: 5A
- Maximum Continuous Discharging Current: 15A
- In Built Safety Circuitry
- Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
- 4.20V maximum voltage and 2.50V cut-off voltage
- Over 500 charge-discharge cycles
- Max. Size: 18.8 x 69.0mm
- Weight: 48g
- Max. 15A Continuous Discharge Current
