4D Cell Maglite LED upgrade
651bobby
Hi, apologies if this topic has been done to death or in the wrong section.
I have a 4D cell maglite which has an early and relatively cheap LED bulb in - it's output can only be described as highly-disappointing.
Can any one recommend an LED module that will fit in with relatively little or no work and ideally allow it to keep running of the D cells.
Something around the £30 (which is probably about the same in dollars these days) would be ideal.
I've seen this:
http://www.thetorchsite.co.uk/HIGH_power_Multimode_10_watt_Maglite_LED.html
Is that any good?
Thanks
alpg88
that is probably your best bet, as far as cost\performance.
651bobby
Thanks, I am partial to the path of least resistance - so I've bought that module.
I'll need to find some more burly rechargeable D cells now.
