[ QUOTE ]
KingSmono said:
The whole reason it's a 4x is because it has a SUPER efficient LED right?
[/ QUOTE ]
I do not have an Arc4x, but what I've read in PG's posts,
the Arc4 and the Arc4+ have all the same brightness, as this is what they are adjusted to. So the Arc4+ gives longer runtime.
And the Arc4x is adjusted to higher power level (was it about twice the LED power?), so it has shorter run time as an Arc4+.
Although, the range for the Arc4+ makes differences possible. But if you are lucky and get one of the better Arc4+s, you have the same good LED in it as the Arc4x.
If you compare an Arc4+ which just made it to be one (that means taking 1.24A at 3V and brighest level), the Arc4x will be better in efficiency (at the same brighness level)
