Re: WARM on charger: Tigerlight, Magcharger, Stin
brightnorm,
bmsmith nailed it. In short, NO do not leave the lights on the chargers all the time. I leave mine on for a full charge cycle until I am sure that they are charged, then remove them. Either that or I use a peak detect fast charger. HiTec CG-340, to be exact.
The self-discharge of NiMH batteries is bad compared to Li recahrgeables, yes, but as long as you charge your lights every month, you're all set. Even after a month of sitting around a NiMH battery will have well over 50 percent charge left. For example SilverFox left one of his TL's sitting for a month, and then did a runtime test and got 45 minutes (vs. 66 on a full charge).
If you let NiMH batteries sit for long enough without giving them a charge, you risk them going bad. At a minimum, charge your battery packs every 6 months.
Anyway, hope that helped.
