[ QUOTE ]
kfasold said:
Two 150s's will run a P91 just fine. Not sure of the runtime, as my 9P (well, 6P + A19) is my 'tactical' light, and I tend to put it away & pull the L4 when the adrenaline-producing portion of the program is over... <G>
Since the 150s's don't suffer from memory or 'top-off' limiting lifespan, I've got two sets & just swap them off when I get home.
IIRC, there's someone on CPF running a P91 LA in a 6P (w/pyrex lens) on two of JSB's original rechargeable 123's.
[/ QUOTE ]
NOOOOOOOOO!!!!!!!!!! Now you've done it! Now I must buy a P91 as well!!! /ubbthreads/images/graemlins/broke.gif
*pauses to recover from cracking up*
Thanks for the informative reply. /ubbthreads/images/graemlins/smile.gif I'll be ordering the P90/91 once the R123s ship, so I should be able to provide runtime info on the batteries. I've heard about something like 40 minutes for unprotected R123s with the P90, so I'm figuring on no more than 10-15 minutes of light with the P91. But, either way that will still be a huge improvement because then I need not throw three cells away after 20 minutes.
The beauty of the protected R123s is that you can run them on many SF platforms with Pyrex lenses. I'm eyeing the C2 as the new housing for the "Super6" project (R123+P9x). The toughest part is, black or HA3? /ubbthreads/images/graemlins/grin.gif
