Crux
I bought a Dorcy "Super 1 Watt" 3AAA from Target. It is quite nicely made, but IMHO underengineered. There is a lot of extra room inside. Some used well, like the reflector - nearly an inch deep, which produces a nice beam from the meager PXIK low dome (although it has a blue ring around it). And some not used well, the tail cap contains at least 1/2 inch of air, but has no lanyard hole. (Maybe its storage space for a spare Lux? /ubbthreads/images/graemlins/grin.gif don't laugh, read on)
Unscrew the reflector and body tube, pry off the rubber switch button (no worries, nothing will be damaged), and the switch and Lux holders can be pushed out. Carefull here as the switch module is symetrical and can be reinserted backwards, it won't work this way but I don't think it will be damaged.
There is a three piece plastic holder that holds the Luxeon Star in a "pill" manner. But the plastic effectivly traps the heat!?
Behind that is the switch circuit, also neatly housed. Dorcy uses an unmarked (custom?) IC and pass transistor to control the ON/BLINK/OFF switching modes. The light would have been better served with a switching or linear regulator to control current. With fresh alkalines, the circuit's pass transistor dropped about 180mV while allowing over 600mA to the Lux. Its sad to see a Lux abused like that... /ubbthreads/images/graemlins/icon23.gif
Surely there is something that can be done with this light, but I'm not sure how cost effective it would be.
I think a 18600 LiIon would still leave room for a linear current regulator and heatsink... well, just food for thought.
