Came across this in another post before the CPF outage last night. Went and found some stuff on it. I must say I'm not excited about it as I'm leaning to smaller lights. But another 'major' making an LED light is good news.
Stanley product description.
[ QUOTE ]
Six bright-white, solid state LED bulbs for extended run-time capacity and long life
Anodized aluminum space frame construction for durability
Graphite ABS composite case
Shatter-resistant polycarbonate lens with impact resistant rubber ends
A low-power indicator light with electronic circuitry helps the user know when the batteries need to be replaced
A four position switch to control the amount of light generated: High/Medium/Low and Off
The flashlight allows you to pre-select the amount of run-time required.
Can be used with 3, 6 or 9 AA size batteries depending on usage requirements
Weight with 9 batteries is 1.01 lbs.
[/ QUOTE ]
Stanley press release.
and on eBay of course /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
[/ QUOTE ]
