here is a thought:
The outer circle shows the inner dimension of a maglight head..
I have cut down IMS17 reflectors doing a test and actually it made for an extremely nice beam.. it made a wide beam that was much more useful for normal walking around etc.. i did not loose too much brightness in the center and gained some more width..
the same effect should happen in this case.. and 2x27s cut down in this fashion should make for something on the order of a 3500 lux light with 2 emitters.. compare that with my 3x17s which is 2500.. or 2x20IMS which is 2500.
it will be tricky to get the depth needed but with only two emitters you will not need anywhere near as much heat sinking.. and you will also get a lot more runtime.
I am working on a 3x20 design right now and it would be interesting to see if i can get a 3x27 design based on this model.. it'd be a hell of a lot more difficult to cut the shapes for the 3-up model but it would make for a more symmetrical beam.. this beam would be distinctly oval (but very useful because of it.. it would be much nicer than the typical 27 beam.. maybe more like the 20).
This solution would be easy to cut down.. i use a dremel and either my diamond wheel or emery wheel to cut or a jewelry saw.. using a sanding block would get the edge nice and flush to mate them.. quite possibly could use model cement or something to meld them into one but that would not be necessary. The biggest hurdle would be fitting the length into the head of a maglight.
I guess this is definitely a 'thinking outside the box' solution.. but i can tell you i was extremely happy with the results with the 17IMS that i cut down to 12mm wide in a 'test case' for my MM which is only 12.7mm wide (making it quite difficult to fit in a 17mm reflector).
-awr
