KevinL
First of all a huge thank you to Batterystation for making this possible. /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/bowdown.gif
Remember: Support your dealers even if it means paying a little bit more than rock bottom price - yes, I have done that in the past and will do it again - so that your dealers will be there for you when you need them most. They too have to make a profit so that they can stick around.
Now, with the commercial break over.. my thoughts on the HDS /ubbthreads/images/graemlins/wink.gif
What can I say, awesome. You guys probably know me and my taste for Surefire lights by now, with nine of them, that's more SF than any other brand of light I own. I own the L1 LumaMax (with KL1-4thgen optic) as well, which is their 1-cell variable power light and something that would be close enough to be comparable to the HDS. But the L1 has some serious, serious competition in its price bracket if you think about the Basic 42 at $125 (MSRP), same as the L1's MSRP.
My thoughts are based on the 60, since I got that, but the 42 has its virtues as well - for one, longer runtime. HDS's site says 80+ minutes on primary lithiums, which is substantially better than the 30+ minutes for the Basic 60.
Though I must say I really like 60 lumens - at full blast this light even gives my U2 a run for its money! Admittedly I can't do full pack discharges at full blast the way I use my U2, but it's very impressive. It's almost as bright as my level 5 (on an exceptionally bright U2 to begin with).
The interface is simple enough for my fish net of a mind to grasp. Why a fish net... well, lots of stuff goes in and straight out, occasionally something sticks. It is as easy to use as they make it out to be and the 4 brightness levels are very well thought out. Initially I dismissed 10 lumens as 'a bit too little' preferring at least 20, but in the field it is far more useable than I assumed. Besides, holding down the switch gives me an instant 60 lumens.
Runtime is the HDS's best part. On non-retina-searing levels, runtime is amazing. I could use the lowest level as a nightlight. The 2-lumen second lowest level is directly equivalent to the SF L1's low level. L1 is brighter vs 3rd level (10 lumens), but obviously, full blast STOMPS the L1 flat. That's a one-cell HOLA if there ever was one.
The SF F04 beamshaper fits. nuff said.. for those moments where you must have a diffuse light.
The HDS's reflector beam does have a little bit of a slightly dark center, but this will only annoy the donut hunters and whitewall hunters /ubbthreads/images/graemlins/wink.gif My U2 has a donut too if I care to look for it on a white wall but this does not detract from the light's useability in the field.
Beam pattern closely matches the SO17XA reflector (IMO). Little bit tighter than the SO17XA. Great beam, metal reflector, and the moment I looked into the light's front end for the first time I saw the trademark green reflection of the UCL's AR/AG coating. /ubbthreads/images/graemlins/happy14.gif
Clip.. enuff said, I am waiting to get screwed by AWTYD. THANKS DAD!! /ubbthreads/images/graemlins/grin.gif
HDS already knows this so I won't say too much other than the clip is an imperfect companion to the IMPECCABLE finish of the light. The knurling is much less aggressive than SF's knurling, it reminds me of the smoothness of the Arc AA I handled recently. Note the AA and the AAA's finishes are very different, I was surprised by it (only own the AAA).
In this department I must say that SF's clip is better. I really like the E1e's clip. (personal preference)
But then again I found the perfect carry solution for the HDS anyway. The HDS is around the size of the E1e+KL1, heavier, but still fits perfectly:
The SAK holster wins yet again.. this is a holster from one of their smaller Tinker knives, but it works great. /ubbthreads/images/graemlins/thumbsup.gif
Of course, the CountyComm belt of last resort is nice, too /ubbthreads/images/graemlins/smile.gif
