I'm having trouble picking up several stations below the 100 Megahertz frequency, my college radio station is very weak, the only way I can pick it up is with a shortwave radio with an external antenna attached to it - even then it has static. I currently have a "T" shaped antenna that I'm using, I've tried some rabbit ears, my next attempt is either a small square passive FM antenna or a powered antenna.
I'm looking at the Terk - FM Indoor Antenna and the Terk - Amplified AM/FM Indoor Antenna
For a visual here's a link. They are the third and fourth down respectively.
Any thoughts/experience with a passive vs. an amplified or powered antenna? Any models you would suggest? I'm not looking for the most expensive one, I'd like a reasonablely priced antenna.
