brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
Nuwai has established a deservedly good reputation on CPF and I have purchased several of their lights over the years including three highly-reviewed lights: the QIII, TM-301X-3 (2x123 LUX III) and the TM-301X-5 (2x123 5W).
Despite the general excellence of these lights I've had some problems. Out of four QIII's two failed completely, one during normal operation and one that rolled off a table (approx 28" height) onto a wooden floor. Sudden death in both cases even after replacing the batteries with fresh ones.
One of my two TM-301X-3's failed after I accidently dropped it from about two feet onto a wooden floor. I just got the TM-301X-5 which I have used for only 20-30 minutes without incident.
So, out of 7 lights, three have failed, a failure rate of
43%. I also have two other Nuwai lights, the AL-606 which combines an incandescent central bulb with surrounding selectable 5mm leds, and a larger precursor of that light. I have used the 606 extensively over the past year. It has been banged, dropped onto concrete and otherwise abused with no problems.
In the past I have "torture-tested" several MagAA dropins with no problems. I have also used L4's, Alephs and ARC 2AAs in rough country, occasionally dropping them on rocky terrain with not a single functional problem (though they don't look quite as pretty as they once did).
I like my Nuwai lights but I don't fully trust them anymore and I wonder if I am the only one to have had these problems.
Brightnorm
Brightnorm
