re: how to figure runtime using a two-stage hi/low-
wayne said: "It would be easier and simplier to assume a simple range of ~10mA to ~30mA and divide this by the Amp/HR capacity of a standard CR123 battery. Your runtime should fall somewhere between the min/max runtime estimates from above.....If a CR123 battery has 1500 mA/HR capacity that would result in 50-150 hour runtime range for this light for the low level. (1500/30, 1500/10)."
sorry, i'm confused.
for example, using a real situtation, i have three different hi/lows for my Firefly: 32 ohm, 16 ohm and 10 ohm.
i know from testing that the 32 ohm produces the dullest beam and the 10 ohm delivers the brighest beam.
using this formula, if i divide 32 into 1500 (mA of 123 battery) i get approximately 47 hours of run time.
or if i use my 10 ohm 2-stage (10 into 1500) i get 150 hours runtime, yet this is the BRIGHTER BEAM.
how can i get more runtime AND more light output, at the same time?
